Question about Neff U1721 Double circotherm Electric Oven
Please advise how to reset the time clock on a
Can you please advise how to reset the time clock on a NEFF double oven. It has been disconnected from mains.
Thanks
Chris
  • Anonymous Jan 08, 2010
    Thank you very much, it is quite bewildering without an instruction manual.
    Best regards
    Chris
    New Friend:
Hold down 2 buttons - the first button on lhs "timer bell" the "hand" button and then use plus and minus with the other hand to set the time.
Posted on Jan 08, 2010
6ya staff
SOURCE:
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 | Ovens
Can't adjust the clock on my 1442 Double Oven
Press the left button 4 times, this takes you to the time which is now flashing and can be changed with the right button. once set, leave it and it will just work from there (i.e stop flashing etc)
Apr 01, 2009 | Neff U1721 Double circotherm Electric Oven
Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Neff U1721 Double circotherm Electric Oven
Need to reset clock timer on oven how?
get a ball point pen press the small button under the clock then adjust the time with the larger button that comes out when pressed on the right
Dec 12, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1641 Switched my oven on the other night it made a noise like a fuse blowing and went dead no lights no controls whatsoever i checked the power and i traced it all the way to the control panel...
check you have power at the clock - the clock terminals not the relay. if not, there is a cut-out stat in the back. check this is still ok. if there is power at the clock then the clock itself may be faulty. you can bypass the clock by joining the terminals to the clock relay and get the oven going this way. another common source of problems is the terminal block where mains comes in and is distributed. these terminal blocks often burn out.
May 04, 2007 | Neff B1641 Single circotherm super...
Neff U1721 Double circotherm Electric Oven Logo
1,312 people viewed this question
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
Domenico Grillo
Are you a Neff Oven Expert? Answer questions, earn points and help others
