Have Model CTF-15. Only dripping half a pot. Has been slowly getting worse. Unit is over 5 years old. Gets moderate use .. one to two pots a day. Has dedicated water line. Starts just fine but runs out of water before pot is full.
Most of these have a control board that times the fill solenoid. On mine it is behind the main burner (you have to take 4 screws out).
instructions are on the back of the panel you remove.
CAUTION DO NOT TOUCH THE EXPOSED ELECTRICAL CONNECTIONS!
There's a small switch on the circuit board that has "lock" & "set" positions. Place the switch to SET, then press and hold the BREW switch until you hear 3 clicks. Release the BREW switch and press it again immediately. Each time you press the switch adds one second to the fill timer. I recommend you add about 5 seconds at a time, then allow the pot to finish filling (don't forget to have your filter funnel installed) when you are satisfied with the final level, place the small switch back to the lock position and reinstall the panel.
ENJOY YOUR COFFEE
Change the in line water filter on the unit.
Unit may also need descaling.
I'm assuming
you've got a coffee filter pot as this is the
most common kind (especially as
wedding gifts).
1. Boil the water.
2. Put the filter (should come with the
pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee
per 6 oz of water.
4. Pour some of the hot water over the
coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and
allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee
grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
