Re: What is the password to activate my motorola H3...
When you pair a device, the passcode is typically set by you. If not, however, 0000 is a common passcode for motorola.
Hope this helps!
Rate my solution!
Try to reset your bluetooth headset by pressing the power key and volume up key until LED glows in a different manner, now you should be able to connect to your mobile.
I have a Blackberry curve and i use this headset. You just hold in the key to your bluetooth till it stays solid blue light, then go on your blackberry under "options" then "bluetooth" then search or add new device. it will search it, pascode is "0000" should load up then. then everytime u put ur bluetooth on and hit the button to turn it on ur blackberry will pop up and ask if you want to use it, just hit yes and your good to go.
There actually is a trick to the HS850 - flip the boom closed, then
hold down the button just until the light holds solid - IMMEDIATELY
after it does flip the boom open and this should keep the light solid.
Then on your cell/device search for bluetooth devices - you should be
able to find it now. Passkey for most devices is 0000.
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
