I have a gas stove in a rental unit.
The tenant moved out. When we lifted the top plate for cleaning, we found the entire backside of the top plate covered in rust, plus rust "dust" was all over, around the burners.
What could possibly cause this large amount of rust in the interior (not the oven) of a gas stove? The tenant lived there only for 2 months.
Thank you for your help.
I have the same problem. This is the second stove to do that in our apartment building. I remember calling the Gas company last time, but I can't remember what the older employee told us why it happened. The only thing I can remember is it had something to do with the gas line..
SOURCE: My frigidaire oven is 6 years old and the clock
your model # is not full but i found unit and the # is 31818541 it coast 177$ in sears part... it is easy to do by yourself just get the right part and call sears part...
good luck
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
SOURCE: FRIGIDAIRE GAS RANGE FGF378WCC
sl, because it't happening to both broil and bake the first thing I would suspect is the temperature probe. You should ohm it out. You can do this either at the board or at the harness connection in back. For the board, remove the back panel, there should be a 8 pin connector to the left of 3 relays. On the harness measure the resistance of the wires going to pins 1 and 2. On the shemantic it shows them being the 2 on the bottom. Should read around 1100 ohms at room temp. If you cant get a good reading on it there, Remove the probe from the inside oven, remove the screws and pull it out until the harness connector comes through, disconnect it and ohm it out from there. I don't think that both ignitors would fail at the same time so Im leaning toward the probe. Catriver.
SOURCE: Oven does not heat
I am having the same problem right before the holiday...can this be by myself or do I need a technician??
SOURCE: How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
