If the streak is like a thin double image line, or the print feels like it rubs off then it is coming from the fuser film. The fusing units are fairly inexpensive and not hard to replace but if you have to have someone do it for you then it might be just as cheap to get a new laser printer.
Look at the exit section of the printer where the paper comes out. The fuser film is a grey "roller" that sits on top of an orange roller. If you can see the grey sheet you may be able to see the defect line in the middle of the sheet that is causing the line.
Good Luck
Cleaning the Print Cartridge Nozzles:
1.
Open the Lexmark Solution Center. Click Start > Programs or All Programs >
Lexmark 1300 Series. Select Solution Center.
2.
From the Maintenance tab, click Clean to fix horizontal
streaks.
3.
Click Print. A nozzle page
prints, forcing ink through the nozzles to clean the clogged nozzles.
4.
Print the document again to verify that print quality has improved.
Using the control panel
1.
Press Menu.
2.
Press the down arrow button until you highlight Clean Cartridge.
3.
Press Select. A nozzle page
4. Print the document again to verify that print quality has improved.
