load test battery
check for tight, clean connections at battery
check neutral safety or clutch safety switch
check starter relay
check ignition switch
check engine and chassis grounds,
below is from the autozone.com site. click on red X's to view files
Four types of starter motor are utilized depending upon the vehicle transaxle and assembly plant location. Manual transaxle equipped vehicles utilize a conventional starter motor which consists of a yoke, an armature assembly, an overrunning clutch assembly, a solenoid, a commutator end cover, a brush holder and a pinion drive lever. Automatic transaxle equipped vehicles utilize a reduction type starter motor which has, in addition to the components found on conventional starter motors, a reduction gear and shock absorber assembly.
In the basic circuit, the solenoid windings are energized when the ignition switch is turn to the
START position and the clutch start/neutral safety switch is closed. The resulting plunger and shift lever movement causes the pinion to engage the engine flywheel ring gear. This movement also causes the starter solenoid contacts to close.
With the contacts closed, the starter solenoid provides a closed circuit between the battery positive terminal and the starter motor. Because the starter motor is permanently grounded to the engine block, the circuit is complete and cranking occurs as soon as the starter solenoid contacts are closed.
When the engine starts, the pinion is designed to overrun and protect the armature from excessive speed until the ignition switch is released from the
START position. With the ignition switch released, a return spring in the solenoid assembly forces the starter solenoid contacts open, breaks the circuit between the battery and the starter motor, and disengages the pinion. To prevent prolonged overrun, the ignition switch should be immediately released upon engine start-up.
See Figures 1 and 2
Fig. Fig. 1: Electrical system diagnosis - No cranking condition
Fig. Fig. 2: Electrical system diagnosis - Slow cranking condition
i had to disconnect the viper from my truck it was draining my battery and now i need to find a solution to the problem or a manual for it
