First of all where is this laptop used? On a hard surface or on your lap? I would invest in a notebook cooler you can get a decent one for about 20-30$. Secondly you may want to get some computer air and blow it into the vents on the laptop. Your last option would be to take it apart and clean out any dust thoroughly although this option is difficult and should only be done by a computer tech. thank you, Lee
And you'll also need to install the Microsoft UAA Bus driver so that the modem and sound card can be detected and installed properly. Here's an entire forum thread on this subject, just go through the explanations and you'll do fine http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1296547702909+28353475&threadId=1274883
If this was helpful and informative please vote with a Thumb Up. Thank you.
greatings and hello
the 1millionth post here, lacking the OS.
HP came with OS/1 , Linux, Freedos, and all versions of windows ever made. (yours, I guess 3?)
so yours is windows 95 (pnp) up. in this case, but what? what windows. (XP up to 10, Im sorry I cant guess that ever)
gee how could (super man doing xrays) the driver is for sure bad. (this tells me not using HP disks)
so learn now that drivers are a 3 way match. Your PC, your CHIP dead, and your OS.
must match. (some devices (chips are 4 ways, web cams inside)
if running XP for VISTA, are you? MS killed dead PNP online
those 2 OS are now officially DEAD>
then you say I installed a OS, and skip
from where? or what disk, and what source
what are the words on the top of the CD?????????????
From HP
FROM MS
from hacking sites endless and full of MALWARE?
we are blind here until you tell what you have
and what you did exactly. (history matters)
use any win-based live cd [or transfer drive to desktop pc as secondary]
to download newer drivers and override broken ones
linux live cd may not work as may not read drivers correctly
Hello, to restart your HP Assistant you must first sure that you have install it in your system then go to control panel then open HP Wireless Assistant then check the properties then modify it. Then press the button with an antenna with a wave at the top to enable your wireless connection. Make sure that you enable your wireless connection for you to have HP Wireless Assistant.
