I forgot my word password, now i want oper that word file. how can it possible? can any way to breaking password of my word file?
Yes, that can be possible & of sure with the help of this Office Password Tool, which can automatically find your forgotten password for protected Office
Word doc, Excel spreadsheet, PowerPoint and more. No matter the document is password
protected to be opened or editing, will help without any problems.
Best regards and good luck to you! - Seli.L
I find a solution for taking back the password of your word document, wish it also works for you:
http://www.downloadatoz.com/howto/restore-passwords-for-microsoft-word-documents.html
A) Open document > Select edit menu > choose select all > then choose copy from edit menu.
Open new document > edit menu> paste.
Select tools menu> choose options> window opens with options. Select form different tabs the edit
tab> make sure that al desired boxes are selected.
Select save tab>choose and mark box>ask about properties
accept or Apply options and close.
Save new document different name. When saving it should ask if you want to save properties>
choose not save. Maybe it asks if you want to modify properties> choose yes> select box archive
amongst read only, hidden or archive.
If this does not work.
B)There are many 3rd party utilities which claim to recover forgotten word password:
The program that I recommend is the Word Password Recovery 5.0 It recovers/removes the "Password
to Open" and "Password to Edit" for you to view and edit the document freely.
http://www.recoverlostpassword.com/products/wordpasswordrecovery.html
Foget word password?check this link to learn how to unlock password protected word document.
When I lost my Word password, I did quite a research only to find out that all password recovery programs can't gurantee successful restoration of lost password. If the password was long and complex, it may take years for them to find it. The only way to reliably remove password from Word 2007 or later version (I had Word 2010) that I have found was online service called www.password-find.com. It exploited some new algorithm that allows removing password instantaneously (removed my within several seconds). However it does not work for 100% of documents, so check it by yourself - maybe the developers improved it since then. If your document is saved in old Word 97-2003 format you may try Free Word Excel password Recovery that someone mentioned already - it may work if lost password is really simple. I hope my post will save you a huge amount of time I wasted looking for some problem resolution.
Word Password Remover will help you break Word file.
Run iSunshare Word
Password Remover and open password forgotten Word file, click "Remove
Password" is OK. And then you don't have to type any password to open Word.
Or if you want to find out forgotten Word password,
you can choose to use Word Password
Genius.
Check majorgeeks.com and freewarefiles.com. I believe both have a password recovery program for Word. If not you can always buy one or contact Microsoft....this assumes you are using a legal copy. Good luck. Tango
I have problem my worg is block i give the passwosd but now forgot plz help me
Asunsoft Word Password Recovery is one of the most popular Word Password Recovery tool in the market, which can help you crack a password of Word in whichever versions, 97, 2003, 2007 or 2010. A password made up of less than 3 characters can be recovered within 1 second. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack, so that it can greatly shorten the recovery time if you partially remember your password.
Asunsoft Office Password Recovery is an all-in one MS document password recovery tool which can crack password of Microsoft Word, Microsoft Excel, Microsoft PowerPoint, Microsoft Access, and Microsoft Outlook. It offers a professional set of features wrapped in a very user-friendly form that is easy to master. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack.
Asunsoft Word Password Remover is a must-have password recovery tool which has the highest speed for you to crack Word password and has 100% recovery rate. The usage is very simple that you just need to click OPEN button to import a locked Word document and click Remove. Seconds later you can open it without password.
SmartKey Word Password Recovery is
easy-to-use software designed to unlock, crack, break word password protected document
in less than 2 minutes and all by yourself.
Dude my frnd hav snd me a word microsoft word file..bt it ois passpword protected ..i dont hav pasword..suggest me plz
Try word password recovery master , it cost's you about 25 $
just search google for the right link
People who have lost their passwords in word dont contact microsoft its against of microsoft policy to break the passwords for documents...........
http://support.microsoft.com/kb/288725/en-us
Just go to akashassociates.co.in and click on adrite
SOURCE: ms word password break
If your password was not many characters long (up to 8 or
10) you can use one of the password recoverer programs available on the
internet (eg. Advanced Office Password Recovery etc.) Just google it, I
am sure you will find the proper program.
Hope this helps
ms excel password break problem, and notify you when a new solution is offered
i forgot my exel sheet password plzzzzzzzzzzzzzzz help me????
i tried a lot of combination passwords but unable to open it
yes i forgot password for my word file
How to crack forgotten MS-Word PAsswod
I forget the Password Of Exel and word Sheet Please Help
HELP ME...I FORGOT MY MS-WORD DOCUMENT PASSWORD
i forgot my password for a particular file
i have fixed my word file with password long back and i amunable to recollect it. It is very important for me to open that file now. please help me how to get it free
password recovery
i forget my word file password
i can not open my ms-word file because i forget my password. how can i open file
I forgotten my password. But at present I need to open this word document. Please help me to solve the problem.
HOW TO BRK THE PASSWORD OF WORD DOCUMENT I HAVE CHANGED IT SEVERAL TIMES I DONT REMEMBER THE LAST PASSWORD
i forgot the password of my word file
i have an important Word-file but forgot the password.
i forgot my password (it's a word file) plz what should i do? i was told about the safe mode, but i don't know how to use it.
i created a word file and thats very imp for me and i hv to make it safe alsoÂ
bt when i need to open it i forget my passwordÂ
so what i do?
i have forgotten my password
I Forget my Ms-Word file password..so How i can open my ms-Word..file..plzzzzzzz tell me.
My Id is..
[email protected]
You can see how to recover word password here:
