2001 Hyundai Accent Logo
Posted on Jan 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a belt diagram for a 01 hyundai accent gl. and does the serp belt drive the altinator?
Patrick Rayome
Level 3:
  • Hyundai Master 1,757 Answers
  • Posted on Mar 06, 2010
Patrick Rayome
Hyundai Master
Level 3:
Answers
1757
Questions
0
Helped
1558471
Points
6122
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
To answer you more direct question about the Serpentine Belt driving the Alternator: It depends on what size engine you have. Also: if you only have 1-Belt: then yes it drives the Alternator. However if you have more than 1-Belt, then look at the Diagrams Provided (on the direct link) to compare which Belt drives the Alternator.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/2001/make/hyundai/model/accent/2001_hyundai_accent_drive_belt_routing_diagram.htm
2002 hyundai accent gl 1.6l, need to change oil pan gasket , exhaust bolts pretty rusted , does the exhaust need to be drooped to remove oil pan ?
The service and repair manual with pictures and diagram will fix all the facing problem on your own and you will get the manual from the given link https://toolsnyou.com
Adding to my question about the correct location of the oil pressure switch. The car is a 2002 Hundai Accent GL. I need a PICTURE OR DIAGRAM of the location on the engine to make sure I'm working
location of oil pressure sensor on 02 hyundai accent gl with a 1.6 liter engine is driver side front of engine. lower near the bottom of the radiator.mind you that is for a 1.6 l
I need a schematic to set the timing belt on a 2000 Hyundai Accent GL
free schematics are hard to get and are usually just general without enough details, try chilton or mitchell on line
What is timing belt? What about timing belt of Hyundai Accent 2000 GL model?
hi
timing belt is the one which controls the firing of the engine.it should be correctly adjusted so that no misfirng takes place.
ya hyndai accent also have that timing belt in it.
1helpful
Diagram
u dont need a diagram all u do is look at it and copy the routing of your belt as well as your tensioner
Timing 2000 hyundai accent,tried puttin new belt on,lined up marks ,then noticed second timin g mark on cam WTF
have diagram can email you need email address to send to, also is it a L Hatchback, GS Hatchback, GL Sedan
Hyundai accent 1.5 diesel timing belt diagram any ideas please
Review the Hyundai Accent Owners Manual (page for 119 for Compressor Belt and 121 for Drive Belt)
Hope helped with this (remember rated this help) Good luck.
Timing belt
it has a tens. just like a serp belt.
Need fuses diagram for Hyundai Accent GL 1999 Look for wipers fuses
This is my msn [email protected] send me a message and i send you a foto of the fuse box with description of the wipers fuses
3answers
Independent belt diagram.
1985 has the 4.1 engine not Northstar and is not serpentine.
r-d03rhtdclj2rhrhwvxvyupdz-d-0.gif Hope this helps.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
