Re: im getting that 5 beepsounds when im power on my
5 beeps means that your motherboard has a problem. Try to reset the bios, pull out the memory cards, clean the area, put them back.
If the problem consists, you have to replace your motherboard.
That sounds like mains hum! Most amps have large electrolytic capacitors to take it out. They can go faulty and let it in. They are high value often around 2,200 or 4,700 UF or higher.
Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
That computer can handle an 8800GTX because it does have 1 PCIe x16 slot for it, which is what the card requires. It also should have enough power for that card as well. I imagine the Quadro is in the PCIe x16 slot though so you have to choose which card to use, not both.
Quadro cards are for workstations that are for 3D modeling and things of that nature. They are very expensive graphics cards but do not play games all that well. I imagine the 8800GTX would play games better, and certainly run Crysis if the resolusion and settings are not on HIGH.
