Microsoft Xbox 360 Console Logo
Posted on Jan 06, 2010
Im sure its very simple but my pad isnt talking to the console,any idea?
Roy Cunningham
Level 1:
  • Contributor 35 Answers
  • Posted on Jan 06, 2010
Roy Cunningham
Contributor
Level 1:
Answers
35
Questions
0
Helped
15762
Points
87
Stupid i know but have you tried to resync the pad with the console.
if the answer the above is yes. then try the pad on another console if it works then the board that is part of the power button is also the wireless receiver and it will have to be changed.
if the pad dosnt sync with another xbox then you know its the pad.
Why the front brake stock I have released the purge
What do you mean purge. There is no purge there is a zerk fitting to bleed the air out of the lines. First of all why was the brake stuck in the first place? If its front brakes i assume we are talking caliper again you dont let us know what kind of car your work ing on. But there are usually 2 fasteners holding the calipeir to the hub assembly identfy those and remove then romove caliper with a large C clamp force piston( on inboard side of caliper) all the way open without cracking open the bleeder screw One may have to remove the outboard brake pad or maybe both brake pads but its a fairly simple procedure. If your talking opened tje purge you must have some idea how brakes work so maybe this isnt over your head. Replace brake pads reassemble. First couple pumps will go to floor that the brake system taking up the slack you put in by opening caliper. Dont crack the system you wont have to bleed it. Should free up stuck brakes dont ever drive car with bleeder valve open
Front brakes
check the rotor to be sure it is flat (not warped).and that the brake caliper has free movement when released.
1helpful
2answers
Trying to pair my new emerson em 227 bluetooth with my playstation 3.I did everything that im supposed to but it still will not work. Maybe this kind isnt compatible with the ps3? The guy in electronics at...
turn ur ps3 off with the on off switch...without shutting it down but make sure you are not playing a game...then unplug it and leave it unplugged for 10 seconds plug it back in and turn the ps3 on (not w the controller)and try again this worked for me...good luck
Only one light comes on while charging and it won't turn on! help-it's Christmas eve!!
if you have a warrenty on it then just go to the store that you bought it from and return for a new one, if you dont have a warrenty then nintendo may fix it but im sure for a hefty price! im sorry this isnt a solution for your christmas grief, im sorry!
My microphone isnt loud wen i record with Mixcraft 3
like when i try to record it lets me but my interface doesnt work an my microphone when i talk to my microphone it doesnt work a bit but when im close to my computer then you can talk but computer is bad quality my microphone is better tho so try to help me on this .........
I get dns error 80710102 and im using wireless i have a 80gb
If you're using a router make sure you've got the latest firmware.
Also make sure you have PNP enabled on the router.
If you don't know what I'm talking about please refer to the router's tech support site on how to access your particular router. They're not all the same.
3answers
N64 Connections
You will have to buy a new cable... there really isnt a fix for a/v cables. with shipping and handling they are like 6 bucks on ebay... Im sure you can also find them at a local electronics store... maybe not quite as cheap though..... sorry there isnt a fix for this... but this is definately the solution :D ... Good luck :D.... Please rate well! :) if you have anymore questions, feel free to ask!
Deader than dead...
im sure the screws are under rubber pads thats on one side of the playstation 2, pull the pads off and im sure the screws are hiding under there been so long since i opened one lol.
hopefully i am right lol..
John
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
