Freezing up can be caused by the GPU and the CPU overheating and before the red lights you can use a good xbox360 repair guide to repair it or you can send it in and get it fixed.
If it freezes and then the next time you turn it on has red lights on the console display check out the corresponding Microsoft articles for the number of red rings on the display. They appear in quadrants on it.
1 red ring
2 red rings
3 red rings
4 red rings
If you do not have any rings, your console may just be overheating. Give it a while to cool down and if that doesn't work, give Microsoft a call: 1-800-4MYXBOX. Good Luck!
SOURCE: Xbox 360 Freeze!!
It's a common fault with X boxes, the red lights indicate overheating, so make sure it is well ventillated and if neccasary you can purchase an add on cooler for the system.
SOURCE: xbox 360 freezing
Also check to ensure that your console has good airflow. The console itself may be overheating if there are too many objects near it blocking airflow.
SOURCE: XBOX 360 FREEZES WITH OUT RROD?
your drive is out or fimware corrupted just check the hardware and flash your console
SOURCE: Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
