IF it says downloading program it sounds like it is trying to update the firmware. Did someone stick a compact flash card in the CF card slot. If so removed the CF card and reboot the machine.
Try loading paper in the bypass on the left hand side of the machine.It may be that you are trying to print a document that is a different size to the paper that you have loaded in the copier.
could be fuser tracking where the pawls ride on the heat roller, could be abrasions on drum, could be main charge corona, could be LSU glass. Can you provide a sample print?
Download the user manual from the manufactures website, I provided the link below. Jam removal instructions start on page 4-12. If you follow the instruction and the printer still indicates a jam then you may have a bad switch or a switch that is stuck down.
hi, I think that You must set parameters for line space,or character space.Also set parameters for margines,L1L2,etc...
have You prescribe manuals? if not, You can download it from Kyocera web site,section downloads.
