You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
Guru, thank you. I had been fiddling with this for about 2 hours not wanting to pull at anything. Anyway as you said it pulled off from one end and the screws i thought impossible to reach suddenly were. Hugely fiddly job but solved. i am a hero in my own home
Thanks
thanks Odin223 - I managed to clear the blockage following your instructions
i was looking all over for a button .... many thanks for that, and to anyone else trying it dont be afraid to pull it off it slips back on nicely :)
Ensure the foot pedal is pressed down fully at the rear of the dyson and check the button beside the on switch is also pressed down ( it will not work properly standing vertical :-)
