normally the speaker wires have a matching coloured wire with a black strip and are distinct from power (red/yellow) , ground (brown/black), aerial (blue) , remote power etc. Not always the same but sometimes grey/grey with black stripe, green, green with black stripe.
It is usually called the remote wire. Either solid light blue or light blue with a white stripe. On the back of the pioneer deck look for the wire labeled REM+ it's just a 12v constant.
this issue is caused by the deck not being hooked up to the constent from the cars battery take the deck out of the dash and get the color codes for the car and the deck and find the wire thats for the constant from the battery and hook up thoes wires
the wires are usually labeled on the deck as follows
labeled wires red .......... ACC yellow......+Battery blue ........ system remote control/remote
unlabeled wires green ...................................... speaker+ green with line ......................... speaker- purple ..................................... speaker+ purple with line ........................ speaker- gray ....................................... speaker+ gray with line .......................... speaker- white ...................................... speaker+ white with line ......................... speaker- black ..................................... Ground orange ................................... dimmer+ (usually not used) orange with line .......................dimmer- (usually not used)
i reccamend you to get the plug in harness that has the wireing alredy done you only have to match up the colors
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
