YOU ARE GENIUS PREMM. i FINE THE CLOGG IN THE EXIT HOSE. FILTER WASE CLEAN. NOW, WHAT IS THE STANDPIPE? I DID NOT TEST MACHINE YET. i WILL LET YOU KNOW AND DEFENATLY WILL RATE. THANK YOU SO MUCH. 3:30AM.YOU ARE GENIUS PREMM. i FINE THE CLOGG IN THE EXIT HOSE. FILTER WASE CLEAN. NOW, WHAT IS THE STANDPIPE? I DID NOT TEST MACHINE YET. i WILL LET YOU KNOW AND DEFENATLY WILL RATE. THANK YOU SO MUCH. 3:30AM.
My machine exit hose wase connected to the sink drain pipe ( like T shape) and gris and other kitchen staff cloged the exit of the wosher waste hose. I eliminate ths with snake, hot and cold water. I was about to buy new machine - and yor advaise and 30 min. of my work solve this. I thank you one more time and oppreciate yor timly wise and simple respond on my problem. Wish you luck and G-d bless. Scorpion and family.My machine exit hose wase connected to the sink drain pipe ( like T shape) and gris and other kitchen staff cloged the exit of the wosher waste hose. I eliminate ths with snake, hot and cold water. I was about to buy new machine - and yor advaise and 30 min. of my work solve this. I thank you one more time and oppreciate yor timly wise and simple respond on my problem. Wish you luck and G-d bless. Scorpion and family.
My washer is in the kitchen (in dishwasher place) connected to the sink drain pipe ( T ) so I do not have stand pipe. Thanks for explanation. Hope this will halp to other people.My washer is in the kitchen (in dishwasher place) connected to the sink drain pipe ( T ) so I do not have stand pipe. Thanks for explanation. Hope this will halp to other people.
AnonymousMar 18, 2014
Is it normal for water to rush out on trying to clean the lint trap at the front bottom rt of the machine? I love this machine but think there must be a better way to clean the lint trap. Also how often should this be done on the Malber WD 1000?Is it normal for water to rush out on trying to clean the lint trap at the front bottom rt of the machine? I love this machine but think there must be a better way to clean the lint trap. Also how often should this be done on the Malber WD 1000?
You can't post conmments that contain an email address.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Thanks for the nice comment....the standpipe is the pipe which is on wall behind the machine, height about 3 feet, some people have this, others direct the waste hose into a sink or washbasin.Thanks for the nice comment....the standpipe is the pipe which is on wall behind the machine, height about 3 feet, some people have this, others direct the waste hose into a sink or washbasin.
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
