RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
you eather have a bad solder connection or a part overheating...this unit has a processor that generate error codes that technician with a special computer interface can read....this is where the troubleshooting begins...first thing a tech can do is check make sure all cables are securely plug in.
