First of all get your connection to teh laptop from the router wired. Then, please ping the routers IP ( Start --> Run -- > cmd --> ping 192.168.x.x.)
Look at the manual for routers IP address.
If you are getting four replies, you have a valid connection, else, try changing cables or ports in the router.
Once this is done remove the cable, try wireless. To do that, ensure, to start off, there is no security on the router. Repeat the ping procedure keeping the router closer to the laptop ( for a good signal strength )
If you are not going online yet, let me know what happens.
hope this helps
Thanks
Ranjit
Does the laptop have a wireless Internet connection card? Have you assigned your router a special SSID (basically a special name for your wireless connection)? Have you attempted to change the channels or the bands on which the router broadcasts its wireless signal?
