Dell Latitude D520 Battery PC Notebook Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One of my friends did something to my computer and i think it inverted the colors. i had to change the display settings to actuall see the screen but now certain colors, or it might just be white or black, still aren't showing up. For example when i open a window, i can't see the exit or minimize button. When he changed this to begin with, all he did was press a few keys and it happened, so I'm assuming there is a simple fix.
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jan 05, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555784
Points
31058
Right-mouse click anywhere on your "desktop wallpaper".
Click Properties.
Did your friend change a "theme", via the 'Theme' tab?
Did your friend change something via the 'Appearance' tab?
Did your friend change the 'Settings' (down to 4 or 16 colors) ?
If you connect an external monitor to the VGA-output port,
do you get the same colours, or do you get "proper" colours?
If you get "proper" colours, it could be that your internal LCD screen is damaged.
If all else fails,
click Start
Click All Programs
Click Accessories
Click System Tools
Click System Restore
Select a "restore point" one or two days ago, before your friend touched your computer, and "restore" your computer to that date/time.
My DSI screen inverted! why?
Bottom screen on NDSL is now has inverted colors, display or ...
Reddit https://www.reddit.com > nds > comments > bottom_s...
Apr 20, 2019 - The system appears to work fine with both DS and GBA games playing without issue, except for the bottom screen which is now displaying inverted ...
Nintendo DSI top screen change color to negative about 20 ...
Jan 26, 2021
Inverted colors on my Dsi... So its been a while that i've had ...
Mar 21, 2022
DSi inverted colors on top screen, any possible cause? Never ...
Nov 19, 2022
The colors on the upper screen of my dsi have inverted for ...
Nov 24, 2022
More results from www.reddit.com
Anyone know how to fix inverted colors on screen? - GameFAQs
GameSpot https://gamefaqs.gamespot.com > ... > Console
Anyone know how to fix inverted colors on screen? Yesterday when i turned my DSi on the touchscreen started up normally. Worked just fine so i started playing.
https://www.youtube.com/watch?v=UxUK1eKpbhQ
Ds lite screen inverted colors Edit: It's fixed now ... - YouTube
YouTube https://www.youtube.com > watch
1:33 Replacing a Nintendo DSi Bottom LCD and Touch Screen · Let's Fix: Sad Nintendo DS Lite Wont Read Games · Jailbreak Your Nintendo DSi In Just 12 ...
tip
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
Regards,
- Mactechtrainer
on Feb 08, 2010 • Computers & Internet
Inverted color lcd
Check settings of display..whether desktop display settings has inverted
Secondly try changing theVGA cable
The colors of my laptop's sreen are inverted. I've tried everything I could think of (display settings, system restore,....), how do I fix this?
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
The colors on my laptop's screen are inverted, how can I fix this?
Both OS X and Windows have inversion options for their displays. Their meanings, on the other hand, differ with the operating system. An inverted display on Windows refers to the display actually being upside down, while an inverted display on the Mac refers to the colors being inverted. Either way, these options can hinder the use of your computer, for obvious reasons. Luckily, an inverted screen can be fixed quickly, on both Windows and OS X.
Right click on the Desktop and select "Properties." Click the "Settings" tab and then select "Advanced." Click the "Driver" tab and then "Graphics Properties." Press "Display Settings" and uncheck the "Enable rotation" option. Click "Apply" and then "OK." On Mac OS X Click the Apple logo in the upper left hand corner of the screen. Scroll down and select "System Preferences." Select "Universal Access" and click on the "Seeing" tab. Check the "Black on white" option and the display should return to normal. Close System Preferences to save the changes.
1helpful
Toshiba Satellite displays a 16-bit color resolution after I replaced the video cable, what is causing this?
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the Display, then click the Settings Tab. You can change the color from 16 Bit and you can adjust the resolution.
You can also get to the display by clicking on a blank area on the desktop and select Properties.
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
2helpful
2answers
Laptop screen blackens - I can just barely see the images on the screen (nothing readable) - am able to use computer through toggle display feature. On shut down the laptop screen flashes with normal...
There are a couple of issues that this could be. Most likely the inverter for the screen is failing. The inverter takes the DC current from the AC adapter and converts it to high voltage for the backlight. If this starts to fail, it can mo lonher regulate the proper voltage for the backlight and the display goes dark. The only other issue would be that the cables attaching the inverter to the screen are chaffed from rubbing up against the hinge points and need to be wrapped and re-routed to avoid chaffing and pinching.
Color changes
1) The display settings on the monitor have changed. Check and/or adapt the settings using the buttons on the monitor. You might wanna try 'reset to default/factory settings'.
2) The computer display settings have changed. Check and/or adapt the settings on the computer, especially scan the 'advanced' menus for keywords like 'contrast', 'brightness', 'gamma'. Or hook up another computer to rule it out for sure.
3) The inverter in the monitor is broken. This is not uncommon and mostly due to filter caps gone bad (capacitors with a bulging on top).
4) One of the backlights in the monitor is broken. This would result in parts/half the screen being much dimmer than the others/half.
LCD Monitors wear in light intensity over time, but when it happened suddenly and very noticeable (and you doublechecked case 1 and 2), it's probably the inverter, as it matches your description (although usually in the end you're only left with a black 'light').
Hopefully you still have warranty so you can get it fixed. If not, a complete inverter replacement can be quite expensive and you're better of buying a new monitor. But when it's only faulty caps, which is not unlikely, it's an easy and quick fix for any electrotechnician, replacement caps are just a couple of bucks. You could have someone or some local repairshop check it out first if you like, could be a cheap fix ...
1helpful
2answers
Display with a red tone
If the redness fades away after it warms up, then it is the bulbs.
Eventually they won't even start up and you may cause damage to your inverter board.
Most screens use 4 bulbs, 2 on top and 2 on the bottom edge.
They can be changed , but it is a bit of work, plus he bulbs average 15 dollars each to buy, so sometimes finding a replacement screen that is good is easier to do.
I have some screens, but I would need to know your model number of the monitor and of the screen.
Fran
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
