Brother MFC-8460N All-In-One Printer Logo
Anonymous Posted on Jan 04, 2010
My Brother MFC 9440cn keeps giving a paper jam error message from tray #1 when there is no jam. Looks like paper cannot feed always
  • Anonymous Jan 05, 2010
    It still is an intermittent feed and then gives error message of jam tray 1
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3516
Points
I have an MFC-8890DW that had a small piece of paper jammed inside the ADF (automatic document feeder). I could use the printer since it was in a "document jam" state. I could see the small scrap of paper, but I could not reach it with tweezers to get it out. I opened the top cover of the ADF and inserted a blank paper on the left most slot by the hinge. I then pressed "stop/exit" which then took the paper through the ADF and when it came out, the small scrap of paper came out with it. Document jam cleared!
Rocska Adrian
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 04, 2010
Rocska Adrian
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
33271
Points
63
Try seting the paper to A4 not leter
  • Rocska Adrian
    Rocska Adrian Jan 05, 2010
    ooo ok so it dosent pic up the paper at all from tray 1 thats easy you need to clean the pic up role (a big ruber role at back end of the tray ) clean it well with alcool
  • Lynn
    Lynn Jul 14, 2014
    cleaned the two small roller at the front top of where the paper tray is, but i still tries 2 or 3 times to pick up the paper but doesn't and then I get the jam message
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
Brother mfc 9940cn paper in try not feed or rolled forward, paper jams
open the back cover for paper jam and check is there any foreign object is present then remove that it and start printing
1helpful
I am having a problem with the paper tray for Brother MFC 8860 dn printer - The paper tray clicks when it is printing a page and then says there is no paper in the paper tray or that a page is jammed -...
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
3helpful
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Printer will not print from tray 1 only MP tray, data light keeps blinking
Have you gone into the printer properties and changed the feed tray? If not to do this go to file and then print ( if hit the print button on the toolbar it will just print), beside the printer model there is a properties button, in there near the bottom you can change which tray you want the paper to feed from. Hope this helps.
Norman Weimar
Norman Weimar
k24674
