If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
check the wireless settings of the router . Make sure that you are typing the correct network key if your network is secured. May be you will need to open the ports on the router. Click Here for more information
Make sure that your router is set for an "encryption system" that is similar to all your computers and mobile devices. Example, if your router is set to encrypt using WAP2, make sure all your devices connect and is capable to connect using WAP2. Or else, set it to WAP and set your devices to WAP also.
I had to restore my laptop to the manufature original settings. My belkin54g wireless router is showing up but it won't let me connect. When I go into network connections iw ould see Not connected firewalled. How can i fix this
please try this tep 1: Make sure that your wireless Internet is turned on and working properly. Step 2: Turn on the Playstation 3 game console. Step 3: Access the "Network Settings" screen under the "Settings" screen in the main menu. Step 4: Select the "Internet Connection" tab and select "yes" when the system displays a new screen. Step 5: Select "easy" on the new screen that pops up asking what type of installation you want to use. Step 6: Select "wireless" when it asks you what type of Internet connection you have. Step 7: Select "scan" on the next screen so that the system searches for all available Internet connections in the area. Step 8: Select your home Internet when the screen pops up displaying the available Internet options. Step 9: Save your settings on the next screen. Step 10: Test the connection to make sure that it works properly. Make sure your wireless Internet connection is at full strength. Hope it helps!
54g implements the latest draft of the IEEE 802.11g specification. The two primary distinctions between 54g and 802.11g are:
1) 54g is designed to enable 54 Mbps connectivity. The 802.11g draft specification makes 54 Mbps connectivity optional, and simply requires up to 24 Mbps connectivity to comply with the specification.
2) 54g products are based on the same wireless LAN chipset, which means they are interoperable. Because the standard is not final, it is not yet possible to test for 802.11g interoperability.
