Iuse to have an 82 720 pickup i still have the manual but it shows no picture shows the wireing schematic i could fax you that if it would help you but i seam to remember that is under the dask near the fuse box not in it . Its with the hazard unit if that still works turn that on and you should be able to hear that and that will lead you to it . If not there are 15 fuses in the box the flasher is the forth one up from the bottom its feed by a yellow and red wire that comes out of the back of the box and the hazard is the forth fuse down from the top of the box also feed by a yellow and red wire . they bolth have two terminals and are rectangler in shape with matlic cases on them .If you want the schematic give my a number to fax it to
this might help 1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door
control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The
door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The
diagnostic connector, is located on the passenger inner fender near the
fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
this should help this should be good for pickup model years 79 thru 95 right turn - green with yellow stripe left turn - green with black stripe backup - red with black stripe taillight - green brake - green with white stripe ground - white with black stripe
Car Radio Battery Constant 12v+ Wire: Blue/Yellow Car Radio Accessory Switched 12v+ Wire: Gray Car Radio Ground Wire: Brown Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Purple Right Front Speaker Positive Wire (+): Green Right Front Speaker Negative Wire (-): Blue Car Audio Rear Speakers Size: 5 1/4′ Car Audio Rear Speakers Location: Side Panels Left Rear Speaker Positive Wire (+): Black Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Red Right Rear Speaker Negative Wire (-): White
