Open the door on the washer,in the middle rear just above the tub you will see the shute were the water comes in to the washer,make sure it is connected to the back panal,if is not than you will nead to remove the washer top door and cover assemble,there is a panal between the dryer and the washer,at the top of the panal on each side you will see a screw,remove them and remove the panal,at the back of the cover on each side you will see a clip with a 5/16 screw in it,remove the screws and slide the cover forward about 1 ",next lift the frount of the cover and on the right side you will see the door switch conneter,unhook the conneter and remove the cover,next you can see the water inlet shute,if is broken than replace it and hook it up to the back panal,next replace cover and panal and run a test run.
