Overnight my Electrolux induction hob touchpad controls showed an 'E' against each ring. What part of the hob might be at fault? Pad attached to glass, circuit board?
SOURCE: Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
SOURCE: Burnt induction hob
hi my name is mark, you can try softscrub or a glass cook top cleaner made by jenn- air or a genaric brand from the supermarket.
SOURCE: Need to fit an induction hob (DTi714V) into a
Go to link below to see how to install.
http://www.dedietrich.co.uk/documents/dti714.pdf
