You can wire them together. just splice the wires on the one that runs weird add wire to it and run those wires into the one that runs good.
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
SOURCE: sony FRV28 Laptop doesn't start
get to the main board of ur system there is a jumper near the battery .
change its position while power is off and get it back to its previous position. this way u will reset cmos to default.
if the computer starts hit delete to enter setup and load system defaults.save changes then exit.
SOURCE: sony pcg frv 37
Well there are some things that might help you with this...
Here are some ideas...
and get a newer one :)
SOURCE: Sony Vaio VGN-CS115J
Do NOT open it..........I'm saying this because it AUTOMATICALLY voids your warranty!!!!!!!
Take it to a certified repair shop/store/dealer.......... ask them to open it and clean the dust out.
Or you can just try using a can of compressed air (found in electronics dpts/stores/computer shops,etc.....) and b low air through all vents and openings.
SOURCE: my sony vaio vgn nw250f
6 months is about right for the fan to become clogged and need re-cleaning. You could try the basics, which is:
1) Don't operate the laptop on your lap.
2) Ensure the vents are kept clear at all times
3) From time to time, simply blow into the vent holes to dislodge any dust.
4) If you can, use a laptop cooler to keep the temperature down in the laptop.
Sorry, I know overheating laptops are a pain, but it sounds like you are already doing as much as you can to reduce/stop/fix this.
