Maytag Atlantis MAV6000 Top Load Washer Logo
Posted on Apr 17, 2017
Replacing time on Maytag Atlantis washer; DIY? Worth doing?
I have a Maytag Atlantis washer, model #MAV6257AWW. Repair person says I need a new timer (when you pull out the cycle knob, nothing happens unless it's on "spin," which is all it will now do. This was very sudden, no warning problems). Cost to do this (close to $300) is over the max we agreed we would spend before just getting a new washer, so I'm wondering how difficult this would be to fix ourselves; the part would cost around $100 retail, from what I can see. Also, I've seen lots of negative reports on this washer--it's probably about 9 years old, has worked fine until now, is it worth fixing?
5 Related Answers
Anonymous
  • Posted on Dec 29, 2008
SOURCE: grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Anonymous
  • 998 Answers
  • Posted on Aug 31, 2009
SOURCE: Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
mmayton
Donna Mayton
  • 135 Answers
  • Posted on Dec 03, 2009
SOURCE: maytag atlantis model mav6257aww
You need to check the waterpump
PRIMOAPPLIAN
  • 401 Answers
  • Posted on Jan 12, 2010
SOURCE: Maytag neptune MAH3000aww washer, will not work on
NEPTUNES HAD A ISSUE WITH THE DOOR WAX MOTOR SHORTING OUT BUT IT BURNS OUT THE MAIN BOARD.IF THE DOOR LOCK LIGHT DOES NOT COME ON REMOVE POWER THEN REMOVE SCREWS OFF THE TOP OF THE TIMER COVER AND TIP IT FOWARD. LOOK ON THE MAIN BOARD AND SEE IF YOU NOTICE A BURNT RESISTOR P-11 POSITION I BELIVE
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Anonymous
  • 335 Answers
  • Posted on Aug 03, 2011
SOURCE: I have a neptune top
Yes Elizabeth if you don't DIY the fix it's no worth having a repair service touch the machine.
I'm an knowledgeable owner and have helped many owners across 4 different forums save their $1K machine at reasonable cost. If you want to DIY I will help at this forum........ Google this ""FAV6800A/FAV9800A Outer Tub bearing replacement"" read thru the post and see if this is for you or someone that can help you DIY the work..............Good Luck dh1200s
9vopy...paste)
MY MAYTAG ATLANTIS WASHER KEEPS WASHING RIGHT THROUGH THE RINSE AND SPIN CYCLES. I HAVE TO MANUALLY TURN IT TO GET IT TO START DOING THE RIGHT THING.
Hi, your timer motor not working,(burnt) or could be mechanical fault in timer, but first replace timer motor, check for timer motor, give appliances store model & serial no. for washer, and let me know when you get it, i will guide you, to install it, yes you can, it's not that complicated. don't forget asked for timer motor. good luck.
2answers
Where can purchase a new timer for my maytag atlantis washer.cost
Hello I would have to know the model number to give you a cost on the timer, You can buy a timer from www.repairclinic.com. Hope this helps :)
1helpful
2answers
Grouling noise in the spin cycle
Maytag Atlantis MAV6548A Transmission R&R
hi thanks for the question johnfmi would let the tech do it only 5 months ago it should be all covered under warranty thanks the appliance doc
3answers
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
2answers
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
2helpful
2answers
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
2answers
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
