When i turn on the remote control to charge the unit, the red on/off indicator light blinks. why? this is for the silver bullet u-control helicopter from brookstone.
Reprogram!
HOW TO PROGRAM Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code Search
Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search Method
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Method 1 Step 1: Press and hold the "SETUP" button until the red indicator stays on, then release. Step 2: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink, then stays lit. Step 3: Enter the 4 digit code for your device. After a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes! Step 4: With your device on, press "CHANNEL UP" or "CHANNEL DOWN." If the device responds, no further programming is required. If some buttons do not operate your device, try one of the other codes for your brand. Note, when all codes have been searched the red indicator flashes rapidly for 3 seconds. Code Search instructions If your device does not respond to any of the codes listed with your equipment, or your brand is not listed, try the following steps: Step 1: Manually turn on the device to be controlled. Step 2: Press and hold the "SETUP" button until the red indicator stays on, then release. Step 3: Press and release the desired Mode button (VCR, TV etc.). The red indicator will blink once, then stays on. Step 4: Press the "CHANNEL UP" button repeatedly until the device to be controlled changes channel. The red indicator will blink, then stays lit. Step 5: Press and release "MUTE" button to install the code. The indicator light goes off.
"1. turn on device 2. press setup (underneath on/off on remote) till red light
stays on the take finger off the button 3. press and quickly release
device button (tv, vcr,etc.) the red indicator blinks off once 4. press
press and release enter to install code"
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
Manually turn on device to be controlled.
Press and hold the "Code Search" button until the red indicator light stays on, then release it.
Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
Press and release the "Code Search" button. The red indicator light goes off.
To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
Repeat again for the third digit in your code number.
1 manually turn on the device (tv, vcr. etc) to be controlled 2.Press and hold the setup button until red indicator stays on, then release the Setup button. 3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once
4. Enter the following codes then press the channel up button and if anything happens the light will go off.
Jenson TV codes 0004, 0009, 0133
If you can't get any of these to work then you will have to do the exhausting manual version.
CODE SEARCH FOR THE RM24912 1 manually turn on the device (tv, vcr. etc) to be controlled 2.Press and hold the setup button until red indicator stays on, then release the Setup button. 3. press and quickly release the desired device button (tv vcr etc). the red indicator blinks off once 4. press the channel-up button repeatedly (up to 300 times) until the device to be controlled changes. The red indicator blinks off with each button press. 5. press and release the mute button to install the code. Then the light will go off.
make sure the batteries are good and installed correctly.
turn on device(manually)
press and hold (setup) button until the red indicator stays on. then release the set up button.
press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit.
press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track.
now press and release the mute button to lock in the code.
how can i charge my helicopter from its remote control
