Question about Konica Minolta DiMAGE Z10 Digital Camera
Power surge on hub port
I am facing problem connecting my z10 with my pc.whenever i connect the usb cable i get the following message "POWER SURGE ON HUB PORT"'A USB DEVICE HAS EXEEDED THE POWER LIMITS OF ITS HUB'
I have many usb devices attached to my pc but never faced a problem like this.
I have microsoft windows xp sp2 running on my pc.
Any genious plz help me
  • 4 more comments
  • jadd Mar 14, 2008
    Problem just started on an IBM t43 laptop, with "power surge on usb port" except in my case NOTHING is attached to any USB port. Could it be a Microsoft 'patch tuesday' generated problem..?
    Thanks, John
  • JonLpic May 10, 2008
    same--onT$43 laptop--error notice just showed up with nothing in usb ports. what to do?
  • swalling21 Aug 04, 2008
    I'm having the same problem as the first guy, power surge on hub ports. This has never happened before. My problem is my digital camera, whenever I plug that in. Any help to fix this would be appreciated
  • cktata Aug 25, 2008
    I am facing problem with my usb port whenever i connect the usb cable i get the following message "POWER SURGE ON HUB PORT"'A USB DEVICE HAS EXEEDED THE POWER LIMITS OF ITS HUB'
  • Anonymous Nov 10, 2008
    the same
  • surfsidereal Jan 15, 2009
    I have the same power surge problem. The camera is 2 years old and it just happenned. Sony wants $151 to repair the camera even though they can't say it's the camera''s fault.
Go to the setup and disable usb ports.. it wd fix it...
Posted on Apr 27, 2008
Pls,Solve this i m in big problem
This is my Email Address:bacchu@navana.com
Posted on Feb 04, 2009
6ya staff
SOURCE:
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Aug 10, 2009 | Canon LaserBase MF5650 All-In-One Printer
Power Surge On Hub Port
try to test the camera on another pc..There is 2 probability here, either it is faulty or else there is something wrong with your usb connection...
Jun 16, 2009 | Logitech QuickCam Pro Webcam
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
Stylus 770 SW Camera - causes Power Surge on USB port
Blown USB ports can happen. Most of the time, they still move power...like you can still charge devices through them, but the device won't be recognized. See if a hub will work.
Rob
Nov 18, 2008 | Olympus Stylus 770 SW Digital Camera
Power Surge error message
BUDDY FIRST TELL ME TYPE OF USB DEVICE U CONNECTED PREVIOUSLY. THEN COMES SOLUTIONS.
Jan 02, 2008 | Compaq NX6110 TFT XGA Notebook
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Konica Minolta DiMAGE Z10 Digital Camera Logo
1,967 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
