It should come programmed with ?F. Have you tried to cook anything in the unit to measure the temperature? That would be another way to easily tell. Set it for the highest you can get it and bake something you normally would be at a lower temp for lower amount of time and go from there.
If your oven has a digital timer then it is capable of being calibrated. Usually the oven is pretty close to accurate but can vary sometimes. In your user guide it may explain how to adjust the setting. You need to purchase a thermometer that you can put in your stove. Set it to 300 degrees and time how long it takes to stabilize. It is possible your stove will not get to 300 but to 270 or 280. If this is the case then the thermostat needs calibration. You can find out how to do this out of your guide or in the tech sheet that you should be able to find on line.
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
I've never heard of any gas stove needing to be re-calibrated annually. Sounds to me like he is trying to sell you some sort of contract for service that is not needed.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
