I recently bought a used Kenmore 158.1703 sewing machine. Machine appears to be in great condition, Motor clean, etc. Was able to wind bobbin. Now, I'm ready to sew, but when I press the pedal, the needle does not go up and down -- i can hear the motor revving, but nothing moves. Is there a certain setting I need to use? Help!
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
The machine sounds like it has threads caught in the bobbin area thus locking the machine up. Check in there and maybe you can pick them out with tweezers. They may need to be 'softened up' with a little oil before you can get them out!.
also Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew.
------This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
Hi,needle of my sewing machine is not going up and down can you please help me find a solution ?
Hello. Check these:
1. Make sure the presser foot is lowered.
2. If the bobbin winder shaft was left in the winding position move it back.
3. If the button hole lever was not lowered when machine was placed in buttonhole mode, lower it. Regards, Joe
SOURCE: can't put thread on bobbin
I cannot tell what your problem is. The winder isn't working? The bobbin won't hold the thread so it will fill?
There are threading guides at the sewusa website that may be helpful as they include written instructions along with graphics.
Bobbin winder ok. Presser foot down. Could not find anything re: button holer,etc. Any other suggestions?
Bobbin winder ok. Presser foot down. Could not find anything re: button attachment. Any other suggestions?
Yes, when I turn the handle, the needle goes up and down. I can manually sew some stitches. Ideas?
