Rca hd/tv d52w19 projection tv
There is an inherant problem with rca tv's
they are not vented properly as far as im concerned
right in front of the fly back is a small part in mine it is grey i think it's a resister
when i took the back off i saw that it was sparking on 1 end ( wholy chit ) scared the **** out of me
if your chip is sparking try this fix if not turning on or no pic look inside and look for burns vthere a tell tale sign of over heating
what i did was crazzy but it worked
i took the stupid chip off by pulling on it what the puck it was screwed any how
then took it to my local electronics store they tested it and told me it was fine just had to but a new 1 since i broke a pin on 1 end
nothing grinding down ends of the case and adding some wire to the pins so i had somthing to solder to
the i re soldered the thing back to the board dam thing was trickey but as long as you are smart and gentl and for god sake un plug the set there is 600 volts inside if not more that can kill you near this chip
it now works fine my 52 inch tv has cost me $7.00 in gas and about 3 hours of time
what i noticed was that the chip over heated at the solder joint and burnt the hole bigger so i soldered and wired to the next conection and re soldered it carefully i did not remove or un plug any thing i just remeoved the board from it's slide mount and carrefully tiped t of only poping 2 conections witch were easy 2 put back on the tv is great it just hates running for 6 monthes at a time hell you shut off your $500.00 computer every once and a while dont you ???
then why would you not shut off your 2000 dollar tv every day
well hope this helps all or at least some of us who cant afford a high priced repair person to show up and tell us it will be 3-400 to fix but they will give us 50.00 for the old chasie and fix it and re sell it for 500 in a refurb tv store like factory direct in canada
Chassis #itc222, tv will not power on
Look on the back for the chassis number. RCA and phillips need the chassis number to be diagnosed.
I have a ATC113CA1 RCA tertainment Series Tv. I turned it off in the afternoon and that evening it won't turn back on. A black screen. When the on button is pushed the green light blinks three times and quits.
my tv d52w19 turned on with a sssh noise then would shut off by itself about a half hour later... after about 2 minutes i could turn it on again with no additional problems... this happened for 3 days then today it tunned off would not go back on - slight burning smell... i unplugged and do not want to plug back in... the chassis is itc222... i have only had for 19 months !!!! what is the cost to repair ??? why would something burn out so early????
RCA DW52W19 Chassis: ITC222, Serial: F016C30M0 - Set would turn itself off and there was a crackle from the back. I took off the back panel and tried to power up and flames came from one of the circut boards. The spot is labeled "CL031". Do I replace the board? Where to get them? Any help would be great. Thanks
TV will sometimes shut off by itself and then turns back on by itself. Sometimes when turning on, it will flash three times and not turn on. After several attempts it will come on. If I push in on the power cable on the back of the TV, sometimes this will work ok.
Husband turned off TV today when cable went out and now won't power back on. Only had the TV about 3.5 years. VERY disappointed considering the amount of $$ we paid for it!
I have the D52W19 , ITC222 for about 3.5 years and when I try to turn it on the green light comes on then shuts off, comes on and shuts off, it does that about 2-3 times and nothing happens no sound or picture. Then it takes about a minute or two before you can try it again! What can it be?? I've read about a flyback model # 259296?? Any Ideas??
i have the same problem. my tv power light comes on and goes 3 times tv never comes on. my model number is D52W20. someone please help
Green Power light comes on and off on and off but nothing.I have a ATC113CA1 RCA tertainment Series Tv. I turned it off in the afternoon and that evening it won't turn back on. A black screen. When the on button is pushed the green light blinks three times and quits.
