I have this set but when i switching on this set i get a message"Please Register", but i m unable to regiater my base station as i dont know the base station pin of manufacturer please give me that pin so that i can register my base stations
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
1. On the base station: press and hold the registration/paging key for min. 3 sec.
2. On the handset: within 60 sec. of pressing the registration/paging key;
Select MENU then Settings then OK then Handset then OK - Register HS then OK -
Enter the system PIN of the base station (the default PIN is 0000). Then press OK.
Registering now flashes in the display.
Registration takes approx. 1 minute to complete.
Thanks for using FixYa. Please do leave a vote for the help.
siemens 2415 says please register how do i register
Base set registered Hand sets will not register
I have disconnected the batteries and the base station to reset but no change
