My parents have had their Panasonic KX-TGA101 for a little over a year and it just stopped working. It no longer rings when a call comes in. Plus when we try to answer a call or place a call all we get is a busy signal both auditory and in the display window.
By jim_giardine on Jan 03, 2010
My
SOLUTION: you might want to change a new phone line, that's maybe the culprit, most of the time is the phone line is worn out first due to too many reasons.
hi I'm a electronics tech and just had this problem so this is a simple fix it is a case of the handsets are not connecting to the base unit correctly.
The fix is turn the power of the base unit (pull the power plug out and leave it for about 30 secs the re apply the power, the follow the instructions for handset registrations and this should fix it note you will might also have to have the handset in the cradle to register it
