I cant connect my daughters Ipod Touch to the internet on my Siemens SE 572 router on Orange. I have rebooted the ipod and downloaded latest software for ipod. Still no luck anyone help?
I think there's a connectivity problem with your router please try to change it ...it will help a lot and buy a different company's router this time.
Please rate.
Check the type of encryption the 572 is set for, I've found a few cases where it needs to be WPA and not WEP.
As a temporary measure, you could switch off wireless security.
Lastly, check your not getting a channel conflict, if a neighbour has a wireless access point with the same channel, you may get problems, which will require logging onto the 572 and changing the wireless channel
To connect to the internet using wifi on the iPod touch, just follow the following steps: Firstly, you should be in a wifi zone(an area where you can access wifi) or if you want to use it at your house with your residential internet connection, just get yourself a wifi router(shouldn’t cost more than $50-60) and configure it with your residential internet
Once you are in a wifi zone, on your iPod touch, go to: Settings > Wifi > Turn your wifi ON > Select a wifi network > Key in the WEP(only if asked for) > Connect Once you’re done with this, you should get the IP settings and be able to surf the internet with no problem. Note: At times when you’re too far away from the wireless router or a big thick brick wall is separating you and the wifi router, your iPod might show the network as available and you would also be able to connect to it, but surfing the internet using it would become a problem. If this happens to you, don’t worry, just move closer to the wifi router and it shouldn’t pose any other problems. Happy Surfing!
dont forget to rate me.....
This problem appears most in ZyXEL routers and NETGEAR routers.
On those routers with the original firmware, only ONE computer has internet access at any given time.
So, when your laptop is on you wi-fi, the iPod cannot access the internet.
When the iPod has internet, the laptop cant.
hold the reset button at the back of the router for a couple of seconds, connect your pc and run the installation. During the installation process, it will ask for the ip address, input the new ip address of your new provider.
verify wireless settings in your router. Check if the security enabled in your router is already supported by your IPod touch. Otherwise, set the wireless security of the router to a mode that is supported by your IPod touch.
