Will not play on computer
Before you can transfer pictures or video from your Canon DC210 to your PC you need to finalise the disc in the camcorder.
You
also need to make sure that the DVD drive on your PC is capable of
reading a DVD-R, DVD-R DL or DVD-RW format as these are the only disk
formats that the DC210 will handle. Not all PC DVD drives can read
these formats.
To finalise the disk you must have the power
adapter connected to the
camera, plugged into a wall socket and turned on. Then, switch on the
camera, put it into playback mode, Press 'Func.', select main
menu, select 'disk operations', select 'finalise'. Don't move or shake
the camera or switch it off whilst the finalising step is
underway - this could cause problems.
Once finalising is complete, put the disk into the PC.
Good Luck.
