SOURCE: JVC KD-G720 car stereo - how to change the time?
Press and hold the SEL button to bring up the settings menu. Press and release the tuning (>>>) buttons until you see CLOCK H. Turn the volume knob to select the hour. If necessary, press (>>>) for CLOCK M; adjust the minutes setting with the volume knob. Press SEL when you're finished. An owner's manual can be downloaded from JVC at this link: http://books.jvcservice.com/booklist.asp?Model=KD-G720J
disconnected the battery an lost all the stations got them back now i can't get the time right HELP?
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
