SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
SOURCE: Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
SOURCE: Water will not drain out of bottom of
Check the input to the drain hose to make sure it is not blocked by something like a cherry pit. That could cause the water to not drain fully.
SOURCE: Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
SOURCE: Frigidaire Dishwasher that is not fully draining after wash cycle
It is probably a bad pump.
Hello Emmitt White - Try unplugging the dishwasher or flipping the household circuit breaker off first. Wait approximately ten minutes and turn the unit back on. If the issue persists, it could possibly be a few things: faulty door switch, drain pump or main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
