Samsung SyncMaster 2233BW 22" LCD Monitor Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red screen Screen seems to be brightening and then dimming. It has a very red cast to it.
Anonymous
Level 3:
  • Master 466 Answers
  • Posted on Jan 03, 2010
Anonymous
Master
Level 3:
Answers
466
Questions
0
Helped
182958
Points
1494
It could of course be the screen driver circuit gone bad, but the brightness and color temperature of a LCD depend on two different circuits. I feel it's unlikely that both went south, and the "red cast" makes me think of a loose PC cable. Try unlatching the cable at both ends and reseating it firmly, tightening both retainer screws.
2answers
How do you brighten screen
screen and wallpaper setting turn of auto light and screen will be bright again and not dim.
Brighten laptop screen
this prob is may be with your screen wire it may be short
The display screen does not light up. You can see and use the icons.
1) The power supply for screen starting to fail 2) You must go to the repair shop
God bless you
My screen is dim, i can just make out the screen and what i am writing. I have tried the power saving options, brightening the screen and nothing helps, anyone know what it could be?
have you tried holding Fn and pressing the button with thr brightening symbol. on mine its Fn and F5 for brighten and Fn and F4 for dim.. buttons may vary but this should work if not you may have a fault with the sreen sensor that shuts the screen down when you close the notebook
3helpful
2answers
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
1helpful
Dim and brighten screen
To dim :Press Fn + Left arrow
To Brighten : Press Fn + Right ARROW
1helpful
2answers
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
