Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
Posted on Jan 02, 2010
I have a Lifefitness Treadmill model TR 9100, serial 381872. When I turn on the power switch, the treadmill does nothing. Nothing appears or lights up on the front console. I removed the motor cover and peered into the motor controller (part number AK58-00146-0004). When I turn on the power switch, I see a single digit led display flash through the numbers 8-3-1-0-4 in sequence then go blank. There are two indicator lights on the lower part of the PC board in the motor controller. The one closest to the LED display is red. The other is yellow. Do you have any idea what could be wrong? Can I get a service manual for the treadmill?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1357
Points
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
Lifefitness F1 Treadmill control panel not working
I'm sorry to hear that you're experiencing issues with your Lifefitness F1 Treadmill console. Based on the information you've provided, it seems like there might be a problem with the console itself. Here are a few troubleshooting steps you can try to resolve the issue:
1. Check the power source: Ensure that the treadmill is properly plugged into a working power outlet. You mentioned that there is power going to the control panel, so this step seems to be fine in your case.
2. Reset the treadmill: Locate the reset switch or circuit breaker on the treadmill, typically located near the power cord. Press the reset switch or reset the circuit breaker to see if it resolves the issue. Give it a few seconds before trying to power on the treadmill again.
3. Check the console connection: Open the console and inspect the wiring connections between the console and the treadmill. Ensure that all cables are securely connected and there are no loose or damaged wires. If you find any loose connections, reattach them firmly.
4. Contact customer support: If the above steps don't resolve the issue, it's recommended to contact Lifefitness customer support directly. They can provide specific troubleshooting advice for your treadmill model or arrange for a technician to inspect and repair your console.
Remember to refer to the user manual or contact customer support for model-specific instructions and support. They can offer further guidance and assistance based on the specific details of your Lifefitness F1 Treadmill.
This might help
I have a Life Fitness 9100HR treadmill which i haven't used for a few weeks. When switching it on I just get a single beep but nothing at all (no illumination) on the screen. What could the issue be?
SOLVED: Life Fitness 9100HR Treadmill won't start - Fixya
www.fixya.com/support/t12664522-life_fitness_9100hr_treadmill_won_39_t
1 answer
May 4, 2012 - Typically a non start up of any electrical Exercise equipment raises ... 2 If there is NOFuse and you just bought it new Return it for an exchange. ... can help you resolve this issue over the phone in a minute or two. ... You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
SOLVED: My treadmill life fitness 9100HR won't start - Fixya
www.fixya.com/support/t12664304-treadmill_life_fitness_9100hr_won_39_t
May 4, 2012 - Have you checked the drive belt @ the motor, if it is OK then check the fuse ... can help you resolve this issue over the phone in a minute or two. ... are never placed on hold and get to talk to real repairmen in the US. ... You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good [PDF]
service manual - Shopify
https://cdn.shopify.com/s/files/1/2781/.../lifefitness9100seriesheartrateandtelemetry.pd...
Page 2. Life Fitness 9100 Series Heartrate and Telemetry Equipped Treadmills ... problem shouldarise, turn to the TROUBLESHOOTING GUIDES and attempt to ... If you have any questions or comments please phone, mail, or fax us at one of the ..... Any use of these trademarks, without the express written consent of Life ...
Web results
I have a memory chip failure message. Lifefitness 9100HR. - JustAnswer
https://www.justanswer.com > Electronics Question > Exercise Equipment Maintenance
Feb 17, 2018 - For a few weeks, in the - Answered by a verified Exercise ... I've worked with these models for a long time and haven't seen a memory chip ... [PDF]
Canada's National Visually Impaired Paratriathlon Team - Canadian ...
ccbnational.net/documents/White%20Cane%20Magazine%202011.pdf
Jan 3, 2011 - The CCB members and volunteers did a fantastic ... visually impaired to the public this White Cane Week. ... our members and volunteers have all across the ..... have nothing in their livesto look forward to. I know ... Mr. Riccobono not only successfully .... they decide to switch from thechirp to the Canadian.
Pace conversion treadmill - Treadmilld and machine
treadmilld.machine.s3-website-us-east-1.amazonaws.com/topic-1-6.html
I HIIT 4 days a week, for two separate foot pedals and use the motor, 5 years ... All you have to do is unfold reviews, such as, the many that are available on Amazon. NOTE: Individuals with carl lewistreadmill no power knee, ankle and back issues may enjoy 1967, ...... As usual, there is no one size you feel you should still .
Weslo cadence 75 treadmill - Treadmillay and workout
treadmillay.workout.s3-website-us-west-1.amazonaws.com/category-1-9.html
And for those who just fitness commercial lifetime don't home gym: Treadmill or ... Week 1: Walk continuously selector all the way to the bottom of the weight stack now. ... No matter what your needs are, treadmill for sale you san antonio tx can buy a ... trainer that the two choices. Use life ... Topic: Weslo cadence 75 treadmill ...
Local Life Magazine September 2018 by LocalLife - issuu
https://issuu.com/locallifesc/docs/0918_digmag-reduced
Easily share your publications and get them in front of Issuu's millions of ... Nothing may be reprinted in whole or in part without written permission from the publisher. ... You can makeover just aboutevery aspect of your life - your home, how you cook, ... One article in this issue talks about thechanging communities of the ... [PDF]
33_53 AWP.indd - Brooklyn Paper
https://www.brooklynpaper.com/assets/pdf/33_53bp.pdfDec 31, 2010 - Walder hailed the facility as nothing less than a ... part, and only services a branch line of the Long ... 33, No. 2. DOWNTOWN, PARK SLOPE & BAY RIDGE EDITIONS .... airy - if youcan get past those giant granite bollards .... isn't even built, but one hotel is already .... nounce for afew weeks whether.
Page navigation 1 2 3 4 5 6 Next
Treadmiill keeps saying waxer needs filled after filling it
please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
Inspect spray pattern between 8" (200mm) and
16" (400mm).
If not, verify wax nozzle is clean, hoses are not
kinked, wax bag is not empty, or wax is
contaminated.
http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
God bless you
My lifefitness treadmill gives a static shocks...
hi you have a wire touching the body of the treadmill somewhere, but an easy fix is to go to any car parts shop and buy an antistatic strip. just attach that to the body of the treadmill making sure it is touching the ground, this will def fix your problem. i had the same with mine i spent ages looking for the wire etc but just waisted alot of time. the strip has worked very well.and cheap to buy under £5.00.
2helpful
How do i reset the waxer on a 9100 lifefitness treadmill?
Press these buttons:
101–ENTER–
HILL–RANDOM–
FIT TEST.
Program lights come on. Display will scroll toWAX DELAY OFF.
Press speed "UP" or "DOWN"
to toggle to
WAX DELAY ON or OFF.
1helpful
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
How can i enter in manufacturers configuration menu on Lifefitness treadmill 97ti
To enter the Manager's Configuration, press and hold down the PAUSE key and press the
CLEAR key twice. Continue to hold down the PAUSE key until the MESSAGE CENTER displays
the words “SERVICE MENU”. Then, release the PAUSE key, press the QUICK START
key, and press ENTER. The MESSAGE CENTER then displays, in turn, each of the configuration
settings.
3helpful
5answers
9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
2helpful
Cant get the lifefitness treadmill T7-0 to work
you may need open up the head board and check the switch.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
