Dryers Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need diagram for hunter fan with light kit. Three
Need diagram for hunter fan with light kit. Three wires coming from fan to speed and light controller in canopy. One black, one white, one black and white. Fan receiver in canopy has five wires. One black and one white go to 120V input. Three wires remain, one black, one white and one blue. What goes where with the remaining three?
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jan 02, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3072125
Points
27242
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
The rocker switch next to the hunter switch works the lower light kit and the little bottom switch on hunter switch turns on upper light on fan but nothing else on hunter switch seems to work. 27186
You installed the 27186 to control an existing fan? It's a three speed pull chain fan? Yes and yes,, the fan pull chain must be in high speed.
2answers
How do I wire a light assembly,,,,my ex girlfriend toke it apart when she left...I have everything.need color codes.
See the link below and then enter the model number of your fan in the box. You should be able to retrieve the information you need from there:
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
2answers
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Hunter fans light kit
I have the same fans...love 'em.. this should be a plug up type connection...? ... If you have to "twist wires"...stop and.call your electrician friend to help..there is obviously something different about the one...
.... sometimes the remotes do funny things...make sure you have the fan and remote settings matching...
... on mine, when the power blips off and on.. they fans either go to high speed or quit.. and all the light cut on high..
http://www.hunterfan.com/support
1helpful
I replaced the 3 speed fan switch on my Hunter 21834 ceiling fan/light. The fan only has 1 speed (fast). What did I do wrong? I tagged each wire to match up, but now only one speed.
What was the original reason why you changed the switch? Sounds like you got the hot wire and high speed wire swapped. The hot wire coming from the upper part of the fan should go to 'L' and then the three other wires going down to the little black boxes for the speeds should go to the corresponding 1,2,3 on the switch.
2answers
I found my Hunter Original fan's switch to be frozen, so I went in search of a replacement. I bought a 3-speed switch with similar wiring (red, blue, and black wires). I wired it up and turned it on. ...
I think you have the power wire mixed up. Your power supply to the switch should be black. And in most cases goes the the L-1 labeled on the switch. If you have trouble finding the power just plug the wires in and use a simple light or voltage tester. Once you have the power wire just touch each wire 1 at a time and you can tell the speeds. Once you have the speeds hook them up to low being 1 med.2 high 3. Then your done
Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
1helpful
3answers
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
10helpful
2answers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
