Washing Machines Logo
Posted on Jan 02, 2010
GE washer model WBSE2090A0WW control assembly replacement
Have GE washer (model WBSE2090A0WW) with bad controller assembly. The new part (GEH part no WH12X10176) is different than the old part in that it has an extra circuit board on it that extends out another 7 inches and has two more places for knobs. GE assures me it is the right part. It also comes with two rubber caps and springs. What are these for?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
302
Points
Hi. I was also searching for the same part and got the same result; nooo, the unit is smaller and only has spots for two knobs not four.
have you looked at this site? https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=PARTSRESULTS&AppliancePart=Washers and Dryers_Miscellaneous .... if that link doesn't work try this and navigate thru it.
There is a guy who lives down the street from me who owns an electronics repair shop; I will be taking my control assembly to him. I'll let you know what he says. On my circuit board, there is a "brown" solder joint; all others are the normal silver color. Hopefully the guy can fix the component that hooks up to the solder connection (it's a relay).
I've been having trouble w my washer (same model as yours) for a couple months ~ I've troubleshooted everything!!!
Hopefully we don't have to end up buying new washers!! take care. (I'll let you know what my neighbor says, too ... thx)
How to change or reset pin code on Grundig TV 32 GEH 6600B
Hello Petar,
To reset the pin code on your Grundig TV 32 GEH 6600B, you can try the following steps:
  1. Turn on your TV and press the "Menu" button on your remote control.
  2. Navigate to "Settings" and then select "Child lock" or "Parental control."
  3. Enter the current pin code (if you know it) using the number buttons on your remote control. If you don't know the pin code, try entering "0000" or "1234".
  4. Once you are in the parental control menu, select "Reset" or "Clear all" to reset the pin code.
  5. Confirm that you want to reset the pin code by entering "Yes" or pressing the OK button on your remote control.
If this does not work, you may need to consult the user manual for your specific TV model or contact the manufacturer for further assistance.
I hope this helps!
What does a ge control assembly do
The control assembly does everything except temp. on most washers it tells the washer when to fill how much to fill when to empty when to spin etc. You need a new control assembly or a different washer.
Brand new GE washer only 2 yrs. old stops agitating and spinning. Model #WBBR3NOG2WW. Any help provided would be greatly appreciated.
Probably a bad timer/module control assembly. It works for a short time then the metal contacts get hot and "open up". The timer control mod is what's behind the big knob. About $90.00.
1helpful
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
8helpful
4answers
What does F1 mean on the cabrio washer?
It means primary control failure. The machine control assembly must be replaced. Below is the procedure in checking and replacing it.
  1. Unplug the machine.
  2. Remove the three screws on the rear of the console assembly.
  3. Flip the console assembly from the rear towards the front of the machine to access the machine control assembly.
  4. Check all the harness on the machine control assembly for any loose or bad connection.
  5. Clean the connectors to make sure they properly connect to the machine control assembly.
  6. Reinstall the console assembly and plug the machine to check if the problem is resolved.
    If it is not resolved, replace the machine control assembly.
  • Disconnect all connections from the machine control assembly.
  • Remove the single screw holding it to the console tray.
  • Lift the front of the machine control assembly out from the console tray.
  • Install the new machine control assembly in reverse order and reconnect all connections.
  • Reinstall the console assembly and secure it with the three securing screws.
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
GE washer model WBSE2090A0WW HELP
Sounds like your loosing your cycle timer which controls all the relays.I would try buying a used one just as a test.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
