Suunto Vector Wrist Watch Logo
Anonymous Posted on Jan 04, 2010
How do I begin and stop the gps/measurement of a run
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291820
Points
7081
As you might have already found, their web site does not offer any facilities to download instructions but they do say " If you have questions about this or any other item in our stores, please call us at Toll Free 888-846-3388".
Give them a try, you never know, you might speak to someone who is familiar with the detailed operation of your watch.
9answers
No watch instructions
- CHARACTERISTICS
1. Stopwatch: Measures up to 9 hours, 59 minutes,
59 seconds and 99 with 1 ¤ 100 second readout.
• Lap time measurement: Up to 9 lap times
can be measured. The lap time difference and
the fastest lap time are calculated and displayed
during the measurement.
2. Time/calendar display: Hour, minutes, seconds,
month, date and day of the week.
• Automatic calendar adjustment: Calendar
adjusts automatically for odd and even months
including February of leap years, but not for
February of common years.
• Time indication: Changeover between 12-
and 24-hour indications is possible.
3. Daily alarm: The alarm can be set to ring on a
24-hour basis.
4. Dual time: Time of a different time zone can be
set and displayed.
5. Stroke function: The watch can be set to beep
at a selected rate to serve as a pacemaker in
jogging, etc.
6. Countdown timer: Up to 9 hours 59 minutes
and 59 seconds can be set in seconds.
• “Lap time” refers to an elapsed time required to
cover a given section of the whole distance.
1. At the start of the activity, depress button “D” to
start the stopwatch.
2. At the end of the first lap, depress button “A”.
The first lap time and lap number are displayed,
though the second lap time is being measured
internally.
3. Depress button “A” to release the lap time before
the end of the second lap. The first lap time and
lap number disappear, and the measurement in
progress and “0” are displayed in place of the lap
time and lap number, respectively.
4. At the end of the second lap, depress button “A”.
The second lap time and lap number are displayed,
though the third lap time is being measured
internally.
5. Measurement and release of the lap time can be
repeated by depressing button “A”.
6. At the end of the activity, follow either of the two
methods below.
a. To display the final lap time, depress button
“A”. Then, depress button “A” to release the
lap time, and depress button “D” to stop the
measurement.
* The time displayed when button “D” is depressed
is not the total elapsed time of the
activity, that is, the time that elapsed from
the start until the end of the activity but the
time that elapsed from the start until the
stop of the measurement.
b. To display the total elapsed time of the activity,
depress button “D” to stop the measurement.
7. Depress button “B” to reset the stopwatch.
Stopwatch operation
Depress button “C” to show the stopwatch display.
Start Stop Restart Stop Reset
Accumulate repeatedly by
depressing button “D”.
Accumulated elapsed time measurement
D D D D B
Notes:
1. When a lap time measured is the fastest among
the lap times previously measured, a short beep
rings to signal that the memory has been updated
with the new fastest lap time.
2. The lap number counts up to “9”. After “9”, the
number returns to “1”.
• While a lap time is being displayed, depress button
“B”. With each depression of the button, the
difference between the displayed lap time and the
previous lap time is displayed in the following
order.
Latest lap time ® Lap time difference
Fastest lap time ¬
The selection of the display can be made in the
following order with each depression of button “C”.
* A flashing display mark indicates that the corresponding
function is in use.
- HOW TO USE THE STOPWATCH
• The stopwatch can measure up to 9 hours, 59
minutes, 59 seconds and 99 in 1¤ 100 seconds.
* Even if the stopwatch display is changed to another
while the measurement is in progress, it continues
counting properly. After the stopwatch is used,
however, be sure to reset it as the battery energy
is consumed enormously to shorten the battery
life.
Stopwatch display mark
Stopwatch operation
internally.
internally.
methods below.
measurement.
Notes:
Lap time difference and the fastest lap time
order.
• The lap time difference is displayed without a plus
or minus sign. Instead, the lap number of the
faster lap time is always displayed at the right of
the “–” mark.
Ex.)
Notes: 1. While the measurement in progress is shown
on the display, the lap time difference
and the fastest lap time cannot be shown
by depressing button“B”.
2. While the latest lap time, lap time difference
or the fastest lap time is shown on
the display, the display cannot be changed
to another by depressing button “C”.
* With each depression of button “A”, month and day
are displayed alternately.
* With each depression of button “D”, the display
changes over between the 12- and 24-hour indications.
1. Depress button “C” to show the time/calendar
display.
2. Depress button “B” to show the time/calendar
setting display. The second digits start flashing.
3. Selection of the digits to be adjusted (flashing)
is made in the following order by depressing
button “D”.
4. Depress button “A” to set the flashing digits.
One digit is advanced with each depression of
button “A”. Digits except seconds move quickly
by keeping button “A” depressed.
5. After all the adjustments are completed, depress
button “C” to return to the time/calendar display.
Seconds setting
When the seconds digits are flashing, depress button
“A” in accordance with a time signal. The seconds
are reset to “00” and start immediately.
Note: When setting the hour digits in the 12-hour
indication, check that AM/PM is properly
set. Only “PM” is displayed and there is no
indication for the AM setting. In the 24-
hour indication, there is no indication.
Is the Motorola 16GB Fitness tracker only good for serious fitness freaks?
That's a good question.
There's no doubt that it's a great tool for tracking your exercise stats through gps, and a pedometer and uploads it for you using wifi.
It's not so good for measuring casual exercise and daily activity, so if that's what you're looking for, this isn't what you need.
But if you take your fitness seriously and want a very cool tracker combined with an mp3 for music while you exercise, then this is worth checking out.
1helpful
Timex Ironman Run Trainer 1.0 won't charge
Just fixed mine. While plugged in, depress all the buttons simultaneously for 3 seconds. It should turn on and show that it is charging. The ticking will stop as well.
2answers
How to use Tachymeter in PL-12777JSBS model
Hi John
this model does not have a tachymeter only day date function on sub dials. there is a similar model 10962j which uses the same case this has the tacho function.
How do i set my settings to record the distance on my nb gps runner
On my new NB Runner GPS watch, how do I set the setting back to zero each time so I know how far I have gone ?
The problem I have with it is that the next day when I turn on the run mode it shows the previous day numbers.
Set time on vector lorus digital watch
Stand on one foot, while patting you head and rubbing your stomach... AND THEN... hold the lock/unlock button until the screen changes....the press the start/stop button which should get the seconds blinking so now you can begin to change things, switch to min/hr etc by pressing start/stop again. The orange run/rest button actually does the changing. good luck!
Dec 21, 2011 • Watches
4helpful
How do I set the hour, minute, date etc.
Thank you for contacting FixYa.
    Setting the Time and Date
  1. To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
  2. Using the Chronograph
  3. To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
  4. Using the Split Lap Chronograph Feature
  5. To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
  6. Setting an Alarm
  7. To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
  8. Using the Countdown Timer
  9. To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
Best regards. Jewel
1helpful
2answers
I need an owner's manual for TIMEX T54012 watch. It has the gps to measure speed and distance.
Here you will find full instructions:
http://assets.timex.com/manuals/?timexBrand=core
Rate me, please.
3helpful
Setting the date
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.
Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press lap/rst to return to normal state with you new settings. You can hit lap/rst to return to normal state at any time in the process, for example if you only want to set the minutes, just hit lap/rst after you set the minutes.
Top Suunto Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Suunto Watch Expert? Answer questions, earn points and help others
