97 grand marquis rattling noise sounds like marble when first started goes away when warmed up
The first place you need to start is with an oil pressure gauge. Rattling marble sounds come from engine components that don't have proper lubrication. What happens is when your engine is cold and you fire it up, the oil is really thick. The hotter the oil gets, the thinner it gets. If there is a problem with the oil pump, it will not draw heavy oil, but as it thins out, it becomes easier for the pump to pull it.
So my advice is to get your oil pump tested. That would be a smart first step.
Sounds like your catalatic convertor,lifters?
Marble sounds coming from engine
