I have had the dishwater about 5 years and recently, following the wash cycle with my Miele G464SC dishwater, there seems to be a desposit of water in the integrated outlet part of the door which should dispensing of the moisture, when the door is opened following the completion of the cycle, you get half of a glass of water over your kitchen floor - Any answers how to solve this proble?
Sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
