Nerf Secret Strike As 1 Logo
Posted on Jan 02, 2010
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3396
Points
9
There is a gray battery cover a little bit above the trigger. You will see a screw hole
How do I get my Nerf rival 1200 to fire automatically
https://m.youtube.com/watch?v=spaayNFppaQ
Feb 14, 2016 • Nerf Toys
Once the plug is on the bolt (Fig 3 in instuctions) is there anyway to get it off again??
rcdodge posted the same problem on Aug 15, 2011. I've just posted a solution aginst his question, so try that (it's a bit tricky though).
I have a nerf nite finder that when i **** it back it fires without warning do you have a soulution
That sounds like an internal mechanism issue, parts of the plastic on the inside could have worn down, causing the spring to slip and fire the bullet off.
1helpful
2answers
I put my battery pack in backwords and i cant get it back out
Can you try wedging something in there to use as a lever, like a screw driver or a butter knife?
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
8helpful
Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Jan 04, 2010 • Nerf Toys
4helpful
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
5helpful
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Top Nerf Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Nerf Toy Expert? Answer questions, earn points and help others
