Re: How to add stored phone numbers. I lost my manual.
From the standby screen, press Menu. Scroll to and select Address Book. Scroll to and select Contact List. Scroll to desired contact, press Options Scroll to and select Edit Edit the desired fields, press Save
Press PROG/PROGRAM
Press the button you want to store the number under
Press 2
Enter the number to dial (remember to prfix with your line access code usually a 9)
Press STORE
To Set: Do not lift handset Press FNC button Press the desired “One Touch” Key Enter number to be stored (remember”0” for external numbers) Press FNC button to save To Dial Lift Handset 8 Press desired One Touch key to dial
To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory 1.- Enter to PBX program mode from your station 101 2.- Choose program 001 to enter the quick dial numbers 3.- Choose program 002 to enter (Or change ) the Labels
Hi John, you posted this a LONG time ago.. but I will add a sollution incase anyone needs to find out in future..
to add a number (i.e 01234567890)
1. Lift the handset 2. Press the 'STORE' key, then enter 01234567890 (the number will not be physically dialed - rather, the telephone is memorising it internally) Press the 'STORE' key again after you enter the number then select the button you wish to locate it to.
You may try this:
1. Pick up the handset and listen for a dial tone.
2. Press and release the STORE button.
3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out)
4. Press and release the STORE button.
5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location.
6. Hang up the phone by returning the handset to the handset cradle on the base.
7. To store more phone numbers in memory, repeat steps 1 - 6
Good Luck !!
