I can get the unit to scan to one pc but not another pc I checked all the settings, like IP address etc. and all look the same. Is there some software that needs to be installed and running on the target system to allow it to receive the scan? Or ???
Yes needs to be running pdms communications utility, if thured toat software is installed then make sure that firewalls or antivirus is configured to allow the connection
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
the ip address for the other two computers might have changed... you need to go into the scanner via the IP address of the scanner and change the IP address for the scan to pc folders destination list to the new one for both computers... or change the ip address to the pc name... pc name may work... but IP address will...
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Can you print to your PC? if yes you know how to assign ip address to the copier. I suggest is to go web browser and type the ip adress of the copier. log in to adminstrator the password 12345678 click network scan you have choices which scanning you want. SMB, ftp scan to email. If choose SMB first you have create Folder to your desktop and name it SMB all upper case and right click sharing and permit everyone . Then back to copier web browser click tab scan and type all the names you want. Scan to e-mail you have to click network and enable the scan to email enter the SMTP leave the port 25 do not change assign a valid email address to copier and enter email address of the administrator user id and the last is the pasword. Note: everytime you visit this page you should enter the password. then click the scn tab and enter all your email address. enjoyprograming!!!
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB: I am assuming you have the KM-1820 connected within the network and a static IP address for it. open any Internet browser and go to KM-1820's IP address. You should see the Command Centre web page. Go to Basic page and add/register a contact within the Address Book. Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center). Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Find the scanner on the network... you can use a tool like Advanced IP Scanner to search the subnet and then just hunt down the IP that belongs to the device -- it may not have a name registered. Visit each potential IP via browser (http://192.168.1.50), one will show you the Kyocera web page. The device has two, one for printer, one for scanner.. each one on its own IP....
That's how far I've got with mine - i was hoping it supports SMB scanning, but it may not. So now I am looking for the rest of the setup.
xxx.xxx.xxx.xxx represents the IP address of your Printer.
This should open your configuration interface. In the center of the page there should be a series of tabs: System, Job, File, Print, Scan.
Choose Scan and toward the bottom of your page you should see the destination folder that goes to your now defunct computer. Click on that folder and it should bring up the Job Type Page - yours should be set to File (Scan to PC). Select next and it should allow you to enter the name for the new folder and the IP address for the new computer.
with scan to Email on this machine you need a mail server that is local
with ftp scanning you need IIS running on either XP Pro or server OS
SMB Scanning can be done but only if you are using an eithernet connection
which one of these do you want do to do
