If it is 3 red lights then it is the Red ring of death or RRoD is a sign of "general hardware failure",Itisindicated by 3 red lights or 3 red rings near power button.Itoccurs,when GPU (graphics processing unit) becomes loose. GPUisfitted onmotherboard, when ever mother board heats up GPU becomelooseand greenlight turn into 3 flashing red light. The vibration ofsystemusuallyloose the soldering of the GPU this will freeze up yourxbox360.
You can fix it with this guide.
You need to
have the motherboard fixed, do to this you need to take the xbox360 apart then
reflow the board.
there is a
great 6part video guide on YouTube to view for free. 6 videos from the same
fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually
used the same method to fix over 450 Xbox360 units with no problems at all,
barring a few (but i have done nearly 500 so you expect a few problems along
the way), you just need a few things though like a heat gun and some thermal
paste. sounds hard, but it's very easy once you start!
Hope this
helps in some way.
At one
point 1 out of every 3 Xbox 360 owners experienced this
problem. This is the one error that you do not want to
get.
This highlights that there is a serious Xbox 360 hardware
problem.
Your options are to send your console back to
Microsoft for repair or to fix it yourself. Be prepared to
spend
a nice amount of money ($140 or so) if you are sending your system to
Microsoft and you no longer have the warranty
4 Red
Lights
If
you have to get any flashing lights on your Xbox 360, pray that this is
the one. If the entire ring flashes, it is a minor problem
that
indicates that the AV cable isn't connected properly or in rare
instances, the cable is damaged. Make sure everything is properly
connected and replace it if It still doesn't work.
At one
get.
problem.
spend
Microsoft and you no longer have the Xbox
360 warranty.
If you want to try to fix the problem yourself then you can see reviews
of guides that we recommend to show you step by step how to
perform the repair.
4 Red
Lights
If
that
