If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
1. Press PLAY from your remote control 2. Press the following button sequence: 1590 2379 390 3. Press PLAY again
This will release the region verification in your player(region free). However, some DVDs (multi region in particular) will not play, since they require region detection from the player unit.
all dvd players are region free when you first buy them, they set the region themselves, after 5 dvd's have been played on them. So if you had a european dvd player and played 5 USA dvd's on it , it would lock to the USA region and you would be unable to play european dvd's on it. Exactly what a friend did many years ago when he bought a load of american dvd films from someone and played them on his brand spanking new dvd player :)
if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution.
Mike @ Compurepair.
no problem! I just bought a LG RH265 and made it multi region with no problems:
on your remote-
1) press HOME
2) move to SET UP
3) scroll down to LOCK (no need to enter LOCK options)
4) press "0" seven times
5) a message will appear stating the dvd player is region free.
6) ENJOY!!!
Hi I have some codes but no one for combo, let me know if is another make on it, because some times their name is Daewo combo or other maka, because combo means combinate.
Using the remote control open tray
Press 0, 0, 0
Region selection will appear.
Select 0 for no region (ie. all regions)
Press pause button on remote control.
Turn Unit off and back on again.
It should now be region free.
Test your disk.
