Dell Inspiron 1000 Notebook Logo
Posted on Jan 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ac adaptor use drains batteries
I use my dell inspiron 1000 laptop almost exclusively on ac power but I notice sometimes, not always the battery power begins draining. I have repalaced the adaptor with a new dell adaptor for this model but the problem is still occurring, though less frequently.
Anonymous
Level 2:
Scholar:
  • Expert 181 Answers
  • Posted on Feb 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
181
Questions
Helped
120308
Points
298
As a system gets a little age on it, the battery naturally decays. Also, each time you plug the ac adapter into the laptop, the adapter connection on the motherboard becomes a bit looser on the solder points, all of which contributes to the symptoms you describe.
You could try a fresh battery.
The standard rule is a battery is wireds to last between 500-600 cycles, then it's dead. They claim it's a safety feature.
Good luck, hope that helps.
Thanks
2answers
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 • Computers & Internet
I had my Dell Inspiron 1525 laptop running. The battery was running down so I plugged the power pack into the electrical outlet first and then into the laptop. The screen went blank and I have not been...
Which ever way round you plugged in should not have resulted in what happened.
You should have a green light on the adaptors case when plugged into the mains weather it's plugged into the laptop or not, if not check the plug fuse.
Is it the correct adaptor for the Laptop? TO CHECK look at the underside of the adaptor the output voltage and amps should be the same as on the base of the Laptop.
Hold the power button down for longer than 5 seconds to ensure the Laptop is off.
Remove the battery and try with just the adaptor plugged in ONLY if its the same output voltage as the laptop.
Remove the memory stick and replace then try and boot again this can sometimes reset the computer.
Leave the adaptor plugged in with the Laptop off to try and put some power in the battery and then try with just the battery.
I have a feeling the adaptor is faulty and it was coincidental that the laptop switched off as you plugged it in, I think you just ran out of battery power.
If in doubt get an electrical shop to test the adaptors output.
I have several 19.5V, 3.34A LAPTOP AC ADAPTER FOR DELL PA-12 KA04A
Does not want to turn on
unplug the battery from the bottom,
plug in your ac power adaptor,
if light comes on in the front then it should start
if no light dead power socket or mother board.
time for another laptop
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
1helpful
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Dell Inspiron 9400 will not charge - AC adaptor not recognised
Does the laptop power up just no charge the battery? If the laptop does not power on then you may have a bad power supply in the unit. If it does power up than you most likely have a bad battery connector of blown fuse on the motherboard. The flashing of the BIOS is done with a bootable cd or floppy but this will not keep the new battery from charging. The reason Dell states that you need at least 10% battery to flash a BIOS is because if your AC power goes out while you are doing a BIOS upgrade and you don't have battery power the BIOS will be incomplete and your laptop will not boot again without replacing the motherboard.
1helpful
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
2answers
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
2answers
Battery and or charger
Try removing the battery and see if the laptop works with the AC adaptor. If not either the AC adaptor is bad or the motherboard is defective.
If your battery LED flashes (yellow or Amber) or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
As for the error message “failed DST short test 1000-0146”, this is flagging an error on your hard disk drive. This could be caused by a bad hard drive or just needs to be reformatted.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
